problem when setting cursor position property
I'm trying to use property nodes to set the cursor position programmatically, following an arrow keypress.  When my actual data file plotted, the position assignment doesn't work properly.  If I clear the data from the graph (right click, clear graph), then the cursor responds properly.  I've attached a zipped file with VI that demonstrates the problem.  Sorry the file is large--I had to include my data file to properly demonstrate the problem.
Thanks for any advice that help me clear this up,
Allan
(3,844 Views)
I think maybe you just need to set the 'active cursor' value first before trying to change its position.
Attached is a simplified version of your VI that seems to work the way you want it to.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(3,824 Views)
Accepted by topic author bracker
Allan
Include this code in 'Initialize' state.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,822 Views)
Troy, Any chance you could convert that to LV2010. I haven't updated lately.
(3,791 Views)
Here you go...
(3,781 Views)
