problem with 3D graph
Hi
I am trying to use 3D graph but I have a problem with dimensions, could you help me to find a solution.
the VI is attached bellow.
Message 1 of 17
(5,208 Views)
You're wiring an array of errors to a 2D matrix input...
There's a function for creating a ramp pattern... It's call "Ramp Pattern.vi"
Message 2 of 17
(5,194 Views)
yeah sorry  I did a mistake , I wanted to wire it to the gate voltage Vg.
I correct it here but  i got the same problem.
Message 3 of 17
(5,191 Views)
That value you're wiring to X Matrix is a scalar, while the Y values is an array.
As a result, the X values become a 1D array, while the Y values become a 2D array.
You should initialize an array with the length of the Y array in the for loop, and the value of X. That way you'll build a 2D array of X values, where each column has the same value.
Message 4 of 17
(5,185 Views)
okay I did it but how can i do this (You should initialize an array  with the length of the Y array in the for loop, and the value of X)ni q.PNG
Message 5 of 17
(5,170 Views)
Wire an Array Size to the Y values. Wire the result to the Initialize Array.
Almost there.
Message 6 of 17
(5,165 Views)
I Added an array size to Y then i wire it to the initialize array X . ani q 2.PNGm I correct?
Message 7 of 17
(5,161 Views)
Well, I'd stick to left-to-right programming, but that was what I mend.
Message 8 of 17
(5,157 Views)
i think it works thank you ,now I trying to export the results from this graph to excel but i could not.ni q3.PNG
Message 9 of 17
(5,152 Views)
As that is a different topic, I'd post details in a new thread.
Message 10 of 17
(5,148 Views)
