problem with 4v4i
well guys i'm having some problem here...
i make a program that monitors current and voltage
and send it to a client....
the transmission is ok.. i already fix all the problems with that
but now, my problem is with the calculated valor of analog 2D dbl
i will upload the client and server vi..
the problem is with the server.....
and the sub vi 4V4I.... is only a RMS value from current and voltages
i'm using a voltage variable here.. and the value is appearing at indicators is the voltages at resistance..
but isn't the right value voltage... at past when i used tradicional daq...
i could make a simple calc to correct it...
i will upload a photo of how i corrected this problem in tradicional daq...
but in daqMX it don't work =~~
so any1 could give me a sugestion
how can i multiply each array for a number... to show the correct value??
is like a calibration of my program!
thanks for the help =D
Message 1 of 1
(2,761 Views)
