Showing results forĀ
Search instead forĀ
Did you mean:Ā
problem with DAQ assistant on LABVIEW.
I have a LABVIEW student edition. I needed to use NI USB 6008 to acquire signal but I dont see "DAQ Assitant" on the Express>Input in the block diagram tile  any time I open a new VI. Any assistance will be appreciated.
Thanks.
Message 1 of 14
(9,074 Views)
Were the DAQmx device drivers installed from the device drivers DVD?
Message 2 of 14
(9,071 Views)
yes. The driver was installed.
Message 3 of 14
(9,068 Views)
Do you have any of the regular DAQmx functions?
If LabVIEW was installed first, and the device driver DVD afterwards, there is no reason the DAQ assistant shouldn't be there unless your installation was corrupted.  In which case I'd say you need to repair the installation.
Message 4 of 14
(9,063 Views)
Thanks for your reply. So how do I go about the repair? Though I tried re-installing the driver, but the system was telling that the driver has already been installed so I couldnt go further.
Message 5 of 14
(9,053 Views)
Hi KDGREAT,
To repair your DAQmx installation, go to Control Panel > Programs and Features.  From there select Uninstall/Change on the National Instruments Software entry.  This should bring up a window that allows you to select the NI-DAQmx X.X.X product and then Repair.
Have a great day,
Chris
Message 6 of 14
(9,042 Views)
I have repaired the software as advised but it did not solve the problem. I still dont have DAQ Assistant on my Express VI. Pls I need help.
Message 7 of 14
(9,021 Views)
What version of LabVIEW and what version of DAQmx do you have installed?
Message 8 of 14
(9,012 Views)
I have LabVIEW 2010 Student edition and DAQmx 9.0.2.
Message 9 of 14
(8,999 Views)
The first version of DAQmx that was compatible with 2010 was 9.1.5. The current is 9.2.3.
Message 10 of 14
(8,995 Views)
