problem with SIT
Hello
 i m trying to get the ''dll file'' of my simulink model.when i click  on the INCREMENTAL BUILD option it gets converted successfully but there is not DLL file in the folder.then i checked the option''Generate Makefile''in real time work option. so i got the following error
Error building Real-Time Workshop target for block diagram 'unsynchd3'. MATLAB error message:
Error using ==> issue_inv_comp_env_val_error at 9
Invalid setting for environment variable MSDevDir or DevEnvDir.
The setting is: ''
You can verify the setting by checking for the existence of:
  %DevEnvDir%\..\tools\vsvars32.bat          (for Visual C/C++ 7.1)
  %MSDevDir%\..\..\vc98\bin\vcvars32.bat     (for Visual C/C++ 6.0)
  %DevEnvDir%\..\tools\vsvars32.bat          (for Visual C/C++ 8.0)
so anyone know how to correct this problem or how to get the dll file of the simulink model????
(2,708 Views)
(2,672 Views)
