problem with analog triggering
I have to acquire analog inputs with a special event : analog triggering
I have a AT MIO 169 E 1 device, WIN95 on my computer, and my Labview version is
5.0.1.
I use the 'DAQ occurence config' icon to make an asynchronous acquisition.
I put the input 'DAQ event' to 3 : event=analog trigger but the on-line help of
this icon specifies that "you must use interrupts, not DMA, when using this
data acquisition event"
How should I configure these interrupts ?
Which icon is appropriate to do this ?
I noticed an example in labview/examples/daq/anlogin/Acquire N Sacns A Trig-
Async Occurence.vi :
It works well if I put only the channel 0 in the input "channels" (and trigger
channel = 0) but it doesn't work if I add the input channel
1 in "channels".
Why?
Thanks for your help.
GSMaintenance
Message 1 of 1
(3,469 Views)
