problem with application builder
I try to build a excutable file with labview application builder 6.0, but there was a problem. I am using Labview 7.1 and I don't know if there is a software compatible issue or not. When I opened the tool menue in Labview pane and selected build application or shared library (DLL), the build application window pop up but together with a window showing error list. The first error in hte list is Dist Send Result File To RT.vi, and the second  is Build Appliation.vi. When I double click the block diagram errors (Invoke Node: contains unwired or bad terminal), another authentication window popped up and ask to enter password to access block diagram. But I entred my labview s/n, but it didn't work.
Can some one help me to solve this problem?
many thanks
(2,727 Views)
I don't understand what you are trying to do. If you have LabVIEW 7.1, then you need the 7.1 application builder.  If all that you really have is the 6.0 app builder, I'm surprised that you even got the build app option to display on the Tools menu.
(2,702 Views)
