problem with auto sizing of table indicator in labview
Hello folks,
I have put up a table indicator on my UI such that it covers up the entire panel.The problem is whenever I load a file onto it,it shrinks or expands automatically based on no. of columns in the input file which is undesirable as I want it to be of fixed size (height & width).In simple terms,I just want it to be of fixed dimensions (ht& width) all the time.Any suggestions for this?
(2,175 Views)
I can't duplicate your issue, my table remains at its original size after filling it in from a file. Can you post your VI? What version of LabVIEW are you using?
Things to try: If your window will not be resizeable, you can set  the rows and columns property node, otherwise, you can right-click on the table and select "Scale Object with Pane".
(2,163 Views)
