problem with building a dll
Hello! I am trying to learn how to build a DLL with Labview. I have made a simple VI that concatenates 2 numbers into an array. Then a indexes that array and puts that number to an indicator. This works fine.
But, if I instead invokes the sub-vi Mean to calculate the mean of the array nothing happens. No results at all comes out from the dll.
WHY?
I have seen that the sub-vi Mean is a DLL, do I have to add that in the builder?
/tj
(3,019 Views)
Hello Thomas!
Could you send your program for further investigations?
cheers
Message Edited by AshwaniS on 09-26-2005 03:23 AM
Ashwani S.
National Instruments Sweden
(3,005 Views)
Suggestion from Ashwani solved the problem.
Put the Ivanlys.dll (\Program Files\National Instruments\LabVIEW 7.1\resource) into the same folder as Labview.exe \Program Files\National Instruments\LabVIEW 7.1)
Thank You!
/tj
(2,971 Views)
