problem with button event
I have 3 events in a while loop each of this event are condtioned with value change of a button so we have 3 buttons in totall , now when i press each button each event works fine but when i press them again i expect it to run again but it doesnt so it just runs once , is this expected of an event to just run one time ? and the while loop illtierate only 1 time when 3 buttons value change (when all events are excuted)
(3,085 Views)
You should post the code you are currently working on.
Norbert
Norbert
Expert: Geometry
(3,075 Views)
Accepted by topic author TheTrice
As well as posting your code, remember - if you're trying to use latched Boolean controls in Event Structures, you have to place the control inside the structure itself to ensure it works correctly. Not doing this can often result in the behaviour you're talking about.
For more info on Event Structures:
https://www.ni.com/docs/en-US/bundle/labview/page/caveats-and-recommendations-when-using-events-in-l...
CLA
(3,063 Views)
Thanks that was the problem 🙂
(3,046 Views)
