problem with \ code display
in a string when i put a "end of line" \n, in the txt files it appears a
little square and it doesn't change line.
Thanks all
(3,001 Views)
use carriage return then new line:
Ex: 1\r\n2 in \codes will output
1
2
If you ever get confused, use a text editor (notepad) to make a file in the format you desire, then use Read from File w/ a string indicator w/ \codes on in a small labview vi to see what the proper syntax is.
2006 Ultimate LabVIEW G-eek.
(3,001 Views)
