problem with data reading from scope tds3034c
hi
i have scope of tektronix tds3034c from this scope i am reading my data in computer through gpib-usb-hs cable.
i am facing problem of triggering in this case if i am not triggering scope then i can't able to read the data from scope.
please help required
(2,789 Views)
Hi husssey,
I suggest to open the manual of the scope and read the chapter on triggering measurements. Surely it will support some kind of auto-trigger and it's your duty to configure the scope in the correct manner...
(2,781 Views)
@husssey wrote:
hi
What driver function are you using? The comment in the single channel waveform acquire example makes if very clear what you need to do.
(2,769 Views)
