problem with executable not launching in run mode after installing LabView 8.0.1 patch
After installing the 8.0.1 patch to Labivew Professional 8.0 it appears I can no longer create an executable that launches in run mode.  Is it possible the 8.0.1 patch that I loaded on an XP machine introduced a bug to the application builder?  If so is there a fix in place or maybe I'm doing something wrong when I build the executable.
Jeff
(2,746 Views)
There is also a patch for Run Time.  Did you install this?
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,739 Views)
Thanks for the update Matt.  I wasn't aware of the additional patch for Run Time.
(2,728 Views)
No Problem.  The patch for run time is further down the list.
Link to Patch: http://digital.ni.com/public.nsf/websearch/D5C32AD00F07D7D586257110007B54D2?OpenDocument
Matthew Fitzsimons
(2,725 Views)
