problem with install two DAQ in one PC and missing DAQ assistant
hello
i have two DAQ cards 6023E and 6024 and each of these cards has its own's DAQmx (DAQmx Vresion 8.7 for DAQ 6023E and Version 9.1.7 for DAQ 6024)
and i want instal both ofl these cards together  in one PC with LabView 8
after installing LabView and installing cards if i install drivers from DAQmx version 8.7 i dont miss DAQ assistant but in NATIONAL & MEASURMENT>>DEVICE AND INTERFACE i only have DAQ 6023E in traditional mode and i cant use DAQ assistant and must use traditional DAQ in labview also 6024 is unrecognized
if i install DAQmx ver. 9.1.7, in NATIONAL & MEASURMENT>>DEVICE AND INTERFACE i have both DAQ (not in traditional mode) but i lost DAQ assistant in LabView
what should i do?
Please help me....
(2,776 Views)
Version 9.1.7 is not supported with your old version of LabVIEW. Version 8.7.1 says it supports both of your cards. Why did you install traditional DAQ. You can uninstall that, uninstall 9.1.7 and retry 8.7.1.
(2,764 Views)
Thanks for answer
when i install DAQmx 8.7 and want to use DAQ assistant in LabView 8, after selecting analog input in DAQ assistant LabView ask me for Choosing Physical Device but there is no device in list and it is the reason i need traditional because when i use traditional DAQ in labview DAQ 6023E recognized but DAQ 6224 not work.
what is your Oponin about change Version of my LabView to 2011?
(before i said my DAQ is 6024 but i was wrong and my DAQ is 6224)
(2,750 Views)
Hello Ashkan,
Please can you confirm you are using LabVIEW 8. Your cards should both work with this version so you just have to get the drivers right. Of course if you have access to LabVIEW 2011 I would highly recommend you use that for your application.
As Dennis has mentioned DAQmx supports both cards so you should not need to use Traditional DAQ. Did you completely remove version 9.1.7? Can you send a screenshot of the software you have installed in MAX>> Software.
Kind regards,
Mahdieh G
National Instruments UK&Ireland
(2,733 Views)
Accepted by topic author ashkan
Problem Solved:
i install LabVIEW 2009 and then install DAQmx 9.1.7 and the Problem Solved
thanks every body for their answer's.
(2,718 Views)
