problem with modal dialog?
Hi All,
I have one modal dialog, A.vi, and it dynamically controls (launch, abort) another dialog vi, B.vi, which needs to display on top of A.vi. So I made B.vi also modal. The problem is then I lost contorl of A.vi.   If B.vi is not modal, it won't be on top of A.vi.
How to do this? Thank for any help.
Anne
(3,310 Views)
Hi Anne,
i have a small question. If B should be on top of A, why do you need to control A? Would it be a solution for you if B is not modal, but on top of A? If yes then you can make B frontmost after showing it.
Hope it helps.
Mike
(3,307 Views)
I need to abort B.vi by A.vi, so I still need the control from A.vi
 I tried to set B to non modal and make it FP frontmost, and it doesn't work. Its FP still under A, maybe because A is modal.  😞
Thanks.
Anne
(3,302 Views)
Hi Anne,
maybe it helps if both vi's are floating.
Mike
(3,294 Views)
It works if both are floating, but NOT acceptable to customer, since there is another vi, C.vi, launch A.  If A is floating and the user clicks C on touch screen,
he won't be able to get A FP back on touch screen.   A.vi really needs to be modal.
Anne
(3,292 Views)
Hi Mike,
My problem is reasonably solved, though still not perfect, by changing vis FP behavior between modal or default back and forth.
Thanks a lot for your reply. Have a nice day.
Anne
(3,282 Views)
