problem with multiple axis in XY Graph
Hallo,
I am plotting different variables in the same plot with multiple axis. I have the following problem (see attachment)
the secondary y axis on the right hand side of the plot has a big space from it and one of the other secondary axis on the right falls on top of others. I have tried it in both labview 8.2 and 8.5 with the same results.
any ideas?
thank you in advance,
thodoros
(3,424 Views)
Accepted by topic author theodoros
Try the following moves :
right click-> pop-up menu -> advanced -> Reset scale layout
Chilly Charly    (aka CC)
(3,397 Views)
Hallo,
this seems to have worked.I will test it thoroughly.Do you now what has caused the problem?
thanks a lot!
(3,380 Views)
kindly mark chilly poast as solution, as in future it may be beneficial for others
regards
Regards
(3,371 Views)
21232 a écrit:
this seems to have worked. Do you now what has caused the problem?
First thing to check : was your graph pixel size a multiple of 13 ? did you cross the path of a black cat ? Any broken mirror wire around ?
Actually I have no clue of the problem source. What I know from experience (my first bug report) is that sometimes, LV graphs get corrupted, and a while ago (LV 7.x ?) this restore command was added to take care of the problem.
(3,352 Views)
