problem with mxi-3 card
i am facing the problem with MXi-3 card.
I have a system like this PXI-1000B chasis,PXi-mxi3 card,pci-mxi-3,pxi-6602 card.
I have installed mxi-3 drivers also.
after swithing on pxi-mxi and pci-mxi also getting powerd up.
link led is glowing continously in both sides.power and Tx led's also glowing continously.
BUt, when i am trying to run Mxi-3 optimization code the following message is displaying that is "mxi card is not detected".what could be the reason . please help me out??/
(2,542 Views)
Hey Chanduu,
I had a few quick quesitons. Are you starting your PXI chassis first when you boot up your system? Are you able to see a screen that says "New hardware detected"? Can you go into Measurement and Automation Explorer, and go into the "Software folder" Can you see if NI-VISA, and NI-DAQmx are installed, and what version?
Nick D.
(2,532 Views)
