problem with pop up report
hi,
I am working on a report writing part and writing an excel report. While writing, the excel pop-up. I didn't want to pop up this excel instead want that in the background of Front panel. Looking for help.
(1,849 Views)
Accepted by topic author kashifsherwani
Post your code so that we can have a look at what you have done.
I don't use the report generation toolkit much, it appears that if you set the window state to 'no change' it will not open Excel.
If that doesn't work, post your code so that we can see what you have done
(1,823 Views)
it worked. Thanks...:-)
(1,764 Views)
