problem with port GPIB
Dear all
Hello
I'm trying to control a measuring instrument via the GPIB port. the control interface works fineexcept that: my program runs in a loopthe problem is that from the third execution of the loop the program does not give the desired results and generates the following error message: RSZV is Channel Displayed.vi
thank you
(2,795 Views)
Identify your instrument and post your code if you want to get effective help with this issue.
(2,793 Views)
my intrument is : Rhod & Schwarz  ZVR
The error code is : 1073481729
(2,777 Views)
And how about posting your vi or a snippet of your vi which shows what you're doing in your loop?
That error code looks like a custom error code so posting the VI which generates it may also be necessary.
(2,769 Views)
