problem with probe fonts
I am having a problem with the font size on my probes.  When I place a probe, the label fonts are all 120, and the font in the probe is normal.  When I go into the Tools>Options menu it says that they are all set to 13.
Jim
Jim
LV 2020
Message 1 of 12
(4,166 Views)
Hi Jim,
Could you please post a screenshot to demostrate the effect you are speaking of?  Thanks!
Yi Y.
http://www.ni.com/support
Message 2 of 12
(4,150 Views)
Sure,
Here it is.  I sure hope we can solve this.  as you can see, the probe goes right off the screen, and with no scroll bars, I can't see most of it!
Jim
Message Edited by lmtis on 08-08-2007 07:13 AM
Jim
LV 2020
Message 3 of 12
(4,146 Views)
Try clicking an empty space on your front panel and/or block diagram and check the font size. If that also shows such high value, just press Ctrl+1 and try to create a new probe. Hope it works...
Message 4 of 12
(4,136 Views)
Hi Deepu,
I'm not sure I follow you regarding clicking on the block diagram, but in the font dialog pulldown it shows the font set to 13.  Also, when I place any objects other that probes, the font is normal (13 pt.).
Jim
Jim
LV 2020
Message 5 of 12
(4,132 Views)
Hi Jim,
Does it happen to all your probes?  If it doesn't, I think you might be using a custom probe.  Open the vi of your custom probe and make sure that the application font is set to 12 or however large you want it to be, and recreate your lables and save your probe.
Yi Y.
Message 6 of 12
(4,114 Views)
Hi Yi,
I'm not using custom probes, but I did discover an oddity this morning.  The font for a probe on a boolean and the font in a conditional double probe are normal.  If I place a probe on any other data line, the data font is 13pt but the label font is 120pt.
Jim
Jim
LV 2020
Message 7 of 12
(4,099 Views)
Lim,
Do you use large font sizes on the front panel? I have not checked, but maybe the probe is picking up some property of the control which is the source for the line being probed.
Lynn
Message 8 of 12
(4,095 Views)
No, I dn't use 120pt font anywhere.
Jim
LV 2020
Message 9 of 12
(4,093 Views)
Hi lmtis,
Go to C:\Program Files\National Instruments\LabVIEW X.X\vi.lib\_probes on your computer and figure out which of your probes has 120 fonts and change it.  You can also do a repair on your installation in which case it will fix any modified program files.  I would try looking at the probes VIs first instead of doing a repair.
Yi Y.
Message 10 of 12
(4,082 Views)
