problem with start trigger
HI all,
I would be grateful if there is someone can help me to sort out this problem.
Short explanation:  I an trying to do synchronization between two chassis by using PFI cable trigger, but the start trigger is not working .
Long explanation: I have two chassis , one chassis has generators and other chassis has receivers. I am sending rf signal(Power sweep) from the generator to the receiverer, but there is no synchronization between these two chassis, So I am trying to synchronize them by using start trigger as mentioned in figure 1, but it shows me an error as mentioned in figure 2. I know that there is no hardware issues to prevent do like this kind of trigger and I am sure there is a problem in my code which is difficult for me to figure out what it is? any advice to solve this issue. Thanks in advance
(4,180 Views)
Hi Al-Rawachy,
It could be because you aren't putting the output of the trigger function back into the instrument handle array. Try using Replace Array Subset to replace index 0 of the array with the output of the Configure Trigger function.
If that doesn't fix the problem then let me know and I can have a deeper look at it. If the issue is urgent then I would recommend opening a service request with us if you have SSP.
Kind regards
Pete
Certified LabVIEW Architect
(4,090 Views)
Hi Al-Rawachy,
I have heard this is being handled somewhere else, if you have a solution I'd recommend posting the answer here so people can search and find it at a later date.
All the best
Pete
(4,003 Views)
Hi Pete,
Sorry for being late to answer you, I was in vacation last week, anyway, yeah I really found the solution.
I discovered that when I run the code in highlited (slow speed) the program runs properly, in contrast with normal speed I got error. Thus I added flat sequence to the nitclk initiate as mentioned in the attached file. and the error has gone.
regards
(3,957 Views)
