problem with system exec.vi and windows XP pro (again!)
"hello;
i just change my computer. i was used to use a laptop with windows XP home. Now i have Windows XP PRO.
As i transfer my vi's an error occur. actually i am using 'system exec.vi' to open another vi. It seems there is a problem with cmd.exe (system32).
how should i fix that?
i send the part (using system exec.vi) of the vi which i use to launch a vi from another vi (ouverture.vi). How can i make work with Windows XP PRO.
thanks for your help,
guillaume"
(3,628 Views)
Have you tried using "command" i.s.o. "cmd"?
You could also try the attached vi, that uses a different approach.
Wiebe.
"guillaume trager" wrote in message
news:506500000008000000FCD30000-1079395200000@exchange.ni.com...
> "hello;
> (system32).
> XP PRO.
> guillaume"
[Attachmen
t Start File.vi, see below]
(3,627 Views)
As i am using Labview 6i, i can't open files from labview 7. so that i can't open the VI u've send.
If possible, would you send me a VI from labview 6i.
thanks a lot,
guillaume
(3,627 Views)
Sure.
Wiebe.
news:506500000005000000DC850100-1079395200000@exchange.ni.com...
> Hello,
> thanks a lot,
> guillaume
[Attachment Start File.vi, see below]
(3,627 Views)
Thanks a lot,
guillaume.
(3,627 Views)
