problem with the Labview PDA and file transfer.
I�m using PALM Tungsten T3 to run some applications. The OS environment is Windows XP. When I try to download a data.txt or data.dat file to the pc using the Hotsync, it gives me an error. There is installed datalogmgr that is the application that allows files exchange between Palm & PC.
Error message
Se ha iniciado la sincronización HotSync 03/09/04 16:12:12
Aceptar Calendario
fopen(C:\PDAdata\19_samples.txt) failed
LabVIEW Datalog Conduit ha fallado la sincronización
I have installed the LVPDA_Patch_70f1.rar file (in the correct order). I tried also with another file generated by PDATempData (in the examples) and it didn�t work. I tried Also to delete datalogmgr and download it again. I tried to instal
ll Labview COnduit again. Any idea?
(2,999 Views)
I know its been a long time since your post. Did you make sure to have the directory that you want the file transferred into created on your PC before the sync. If the folder isn't there you will get that error.
Dan
Don't code angry. Dooon't code angry!
(2,922 Views)
