problem with the daq assistant
hi i want to send the 10 bit serial digital data to the external application and i want to receive again 10 bit digital serial data from the external device. for reception i used the daq assistant. it is showing some error. i posted the picture of the code and the error shown by the daq assistant...
(2,973 Views)
Hi ravi bagade,
Can you post screenshots of your DAQ Assistant Configuration?  Is there a specific protocol you are trying to conform to?
Dustin D
(2,926 Views)
