problem with the wifi acquisition
hello all,
  Actually this problem is just screwing me from so many days.I have one wireless adapter(serial to wifi adapter) and using that adapter i had designed one wifi amplifier which will sense biosignals and transmit wirelessly...Ok.Now i started writing an application in labview (receiver ) so that whatever data wifi amplifier is sending i should receive and store in a file.For that purpose i am using TCP/IP vis of labview.But the problem is with the connection.Actually my labview program is configured as server and it waits for some client to connect whereas wifi amplifier is by default it is in client mode.Can anybody please tell where the problem is and please post any VI for the connection?
Thanks and regards,
srikrishna.
Srikrishna
(2,725 Views)
See this and also this.
(2,710 Views)
Hi muks,
   Thank you very much for your reply...Actually in my application, i am not using any WLS carrier and NI C series modules.Just i have a wifi amplifier(we need to run some ATI commands for communication).I want to connect using normal TCP\IP vis.Can you please tell me how to do this?
Srikrishna
(2,704 Views)
