problem with this vi....random behaviour
hi all
i've a problem with this vi....it is a pop up window called by another vi.
when i insert some values and press write it will send the write command and must exit while if i press cancel it must exit directly.
the vi works but if i press cancel sometimes i must press cancel 2-3 times to exit and i can't understand this....
can you see my vi?
where is the problem?
thank you
http://www.sd-studio.it - web design agency
(3,510 Views)
Multiple thread - see http://forums.ni.com/ni/board/message?board.id=170&message.id=195752
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,507 Views)
