problem with update string
Hi
I'm using a string in a cluster.I want the value of the string to be passed to another control when i press the enter button.
The problem is when i press the enter button an empty string is passed to the other control.I tried to use the update while typing property but when i use that my string doesnt show any value entered.
(3,853 Views)
Can you post your code?
(3,848 Views)
That's not where the problem lies.. As Mathan suggested, can you post your code?
(3,835 Views)
HI swathi,
Where are you from. Where you worlk. i am from bangalore.
(3,743 Views)
hi swathi,
 Please check this code out!!
Thanks and regards,
srikrishnaNF
Srikrishna
(3,727 Views)
Hi
Thanks for ur reply..Actually i have found the problem..My control was corrupted.As i replaced my cluster there seemed to be no problem..Anyways thanks again..
(3,717 Views)
