problem with while loop ( without delay)!
I want to make a main VI, that calls some control value from 2 different VI ( position.vi  and value.vi ). I put 100 ms delay in position.vi , and 1000 ms delay in value.vi. But in the main VI, i don't want to put any delay. So I got problem with main VI , it works seem not correct!  How can i fixed it? Thx.
The working way of main VI ( try123.vi)  same with the ideal.vi ( attached).
Message 1 of 12
(4,889 Views)
The ideal.vi
Message 2 of 12
(4,888 Views)
Hi ha noi,
i attached an example of what i mean in the other thread. It is not yet ready, but you can think about it i tell me if it can be a way to solve your problem.
Mike
Message 3 of 12
(4,871 Views)
Thanks mike!
I'm trying to understand your vi. You can try my vi, then you know how it works! I just want to delete the delay! but it not work!
Message 4 of 12
(4,859 Views)
hello ha noi
the other Value you get from the read_value.vi is only to see if it is a new value, right?
Mike
Message Edited by MikeS81 on 01-16-2008 07:51 AM
Message 5 of 12
(4,852 Views)
Do you mean "#" value? It's number of loop  in read_value.vi ( 1 loop => 1 value created).
Message 6 of 12
(4,847 Views)
hi again,
i think this vi now do what you want.
Mike
Message 7 of 12
(4,842 Views)
I tried to run your vi, but it not works in my computer.
I have a question for my vi : i thought the second case structure not works. But the position indicator worked ( it showed the changing of position) so i think it's work. But why the array indicator almost time is [0,0] ?
Message 8 of 12
(4,831 Views)
Hi
now it works. The values are captured by the queue. Now you have to check the main functionalty of that what you want. Smiley Happy
Mike
Message 9 of 12
(4,824 Views)
It's work!  Can you explain the reason that number of main loop increse not very fast? Normally, in few second it can reach more than 20.000 loops ( if i don't put any delay)! Thanks  alot!
Message 10 of 12
(4,815 Views)
