problem with wiring TDS3000
Hello and Good day
Can i do array on the read waveform measurements vi as attached in the attachment. I can't connect the array directly to 'Read Waveform measurement's vi' If can what should i do?
Thanks for helping
(3,236 Views)
You are trying to read multiple measurements?  Use a FOR loop.
(3,234 Views)
Thanks for reply crossrulz
Yes i am going to give multiple input measurement and to read multiple measuremnt that is connected to the 'Read Waveform Measurement .vi' can i do that?
I also attached some jpeg,file if u cant undestand my words.
(3,217 Views)
You can't understand the words that have been given to you in the answer above. You have an array of measurements. The function takes one measurement at a time so place the function inside a for loop and pass the array through the for loop. This is called auto-indexing and a fundamental concept.
(3,213 Views)
Thanks Dennis_Knutson & crossrulz
I figured it out. Thank you so much!! :manhappy:
(3,182 Views)
