problems bundling visa run time with installer
I am trying to build an installer for an application that makes VISA read/writes through a serial port.  I have tried to create an installer for this application but I keep getting a cryptic error that then terminates LV.  I am experiencing the same problem as described in this thread:
I am developing with LV8.2 on XP SP2.  I would like to bundle the VISA Run Time so that I can communicate via VISA R/Ws.  After reading the above mentioned thread it didn't seem like there was ever a real resolution to the problem.  I am bundling the VISA Run Time engine just fine with other projects and I have deleted and started over several times with the installer inside this project, but I keep getting the same error, see attached document.
So are there any ideas short of me having to reinstall LV or VISA?
Thanks in advance!
Dave
(2,884 Views)
Quick update.  I've worked around the problem by creating an entirely new project but that doesn't seem to be a solution to me.  Why is it that I can't just create a new installer rather than a new project?  Any guidance would still be great!
Thanks!
Dave
(2,882 Views)
Dave,
I don't think the problem is with your install of NI-VISA.  It really seems like something in the project is corrupted.  Was this project started under a different release of Labview?
You might try deleting all your build specifications, save the project and restart Labview before creating new build specs.  I think I would nuke the spec for the .exe as well.
(2,876 Views)
Thanks for the reply.
I would agree that the project is corrupted.  I think I proved to myself that this was the case when I created a new project and magically everything worked just fine.  The project was created under the exact same release of LV by the same PC so I am just trying to understand why the project was corrupted while trying to build the installer.
I guess I have my solution now I'm into the deep dark hole of trying to understand why the error occured.  I know once I go down this path there is no returning.......
Thanks!
(2,874 Views)
You might also try creating a simple application in the suspect project and see what happens when you create the installer.
(2,868 Views)
