problems met when synchronizing two PCI 5114 digitizer
Problems are met when we try to synchronize two PCI 5114 digitizer.  we are using the example vi "niScope EX 5112 Synchronization.vi" with labVIEW,  but it doesn't work.  Figure 001 shows the error, and figure 002 show the error after i remove the property nodes on the block diagram. i doubt if there are something difference between the two types of digitizer.  We have the RTSI cable with us and TClk mode works fine. but we couldn't use the TClk mode because it doesn't support RIS.
Any help? Code example is the best maybe. thanks.
Message 1 of 1
(2,339 Views)
