problems with TDMS streaming and Origin
I'm using the example TDMS Streaming - Cont Log and Read Data.vi and I record a file .tdms. But I can't read this file with the program Origin, just with Labview or DIAdem. When I used the example Cont Acq&Graph Voltage - Write data to file (TDMS).vi and I record a file .tdms, this one i can open with the program Origin.
SO, What the difference between the file .tdms create by first example and second example? Why I can't open the first one with origin?
Thanks.
Marcela.
(2,853 Views)
Hi Marcela,
Do you have multiple versions of LabVIEW installed on your machine? The example Cont Acq&Graph Voltage - Write data to file (TDMS).vi should be an old example VI and should not exist in LV 2010 any more. Instead, we have the new examples like TDMS Streaming - Cont Log and Read Data.vi from LabVIEW 2010.
And, the old example should write TDMS 1.0 file format and the new example started to write TDMS 2.0 file format. I guess Origin could not load TDMS 2.0 file format now.
You can refer to the below link for more information about TDMS 2.0 and please feel free to let us know if you have any more question about TDMS. Thank you.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019SWMSA2&l=en-US
Yongqing Ye
NI R&D
(2,830 Views)
