05-15-2008 08:38 AM
05-16-2008 10:42 AM
does'nt anyone have a clue what might go wrong?
I'll try uploading the vI i've created..
thanks
05-16-2008 11:12 AM
bgu_student,
It would definitely be helpful if you could post the VI that is not working for you. Otherwise it is hard to guess what might be going wrong. Just to clarify, is the VI with the Simulation Module that you posted working propertly? For that VI, I would recommend removing the local variables of the 'x' output, since you can simply wire the output back to the inputs in a Sim Loop. This will actually change the behavior of the system slightly. Also, if you could post the VIs, as opposed to a screenshot, that would be most helpful.
Chris M
05-17-2008 04:20 AM
05-23-2008 05:07 PM
05-24-2008 01:40 AM
05-27-2008 10:51 AM
