problems with graphs and tab controls?
In the past I have had trouble with the use of tab controls and graphs. The main issues is that the x and y axix scaling on the graph sometimes gets horribly messed up when you change from tab to tab. This was not the only problem, just the one I remember having the most trouble with. Last I knew was that NI was aware of the problem and was working on a fix for it. Is this fix already implemented in some sort of patch, or will we have to wait for lv 7.0? Also if it is a patch could you direct me to the specific site where I need to go to find it.
Thanks.
(2,840 Views)
Hi Marshall,
what version of LV are you using?
I experienced several problems with tab controls under LV6, partly fixed with 6.0.2.
LV 6.1 seems to be more efficient with tabs.
There isn't any patch to LV 6.1, as far as I know; so if this is the version you are using take it easy and wait for LV 7!
Alberto
(2,840 Views)
I am using 6.1, do you know when 7.0 is going to be released?
(2,840 Views)
I don't really know. But, since I know NI, major upgrades are usually released during summer, before NI-week.
Let's sit back and wait!
Alberto
(2,840 Views)
