problems with report generator toolkit when i use application builder
i use the office report generator to create a excell report, mi application works good, but when i compile it with application builder, the applications always launch a error when it uses the report generator block
somebody know why???
(2,730 Views)
You didn't give an error number, but it's likely that you have the same problem that is discussed here. (http://forums.ni.com/ni/board/message?board.id=170&message.id=105772)
Hope it helps,
John
(2,726 Views)
thanks, i will try this solution, im sure that it will work
(2,710 Views)
