problems with windows 7
When i tried to install labview on my laptop with OS windows 7,its not asking for device drivers.And when i tried to install device drivers,its telling not able to install on 64 bit operating system.
How do i find a work around for this...
Thanks in advance
(4,160 Views)
Hello
Witch DeviceDriver CD are you trying to install?? It is just the latest ine that works with Windows 7. You can download that one here:  http://joule.ni.com/nidu/cds/view/p/id/1451/lang/en
regards
/Klas
(4,149 Views)
What is your labVIEW version?
(4,137 Views)
(4,136 Views)
Sorry for the late reply...
We are using labview 8.0.Is it not compatible?
(3,923 Views)
No, it's not compatible.
Only LabVIEW 2009 is compatible with Windows 7, and if you use 64 bit system, you should use LabVIEW 2009 64 bit also.
If you don't wish to upgrade, move back to Windows XP is your option.
(3,906 Views)
Also i guess you can give a try by using 8 in xp compatibility mode.
(3,866 Views)
