problems writing to parallel port
Hi All,
I need to write an 8 bit bianary data (number) to the Parallel port.  If I use the outport.vi will it strobe or do I need to include the first bit to do that?  Am I addressing the D0-D7 data bits or the strobe also.  Thanks for the insight,  JoePat
(2,787 Views)
What OS are you running.  If it is Windows 2000 / XP you will not be able to access the port directly using the outport.vi.
See: http://www.beyondlogic.org/porttalk/porttalk.htm
If you are using Windows 98 or 95 you shouldn't have an issue using the outport.vi.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,778 Views)
There is an app note at http://zone.ni.com/devzone/conceptd.nsf/webmain/72C6FC6CE4AD4D1386256B1800794596 on using Out Port or VISA Write to the parallel port. Since LabVIEW 7, you can use In Port/Out Port without using a patch in NT/2000/XP.
(2,775 Views)
