programatic control of float array precision?
Using LV6.1, I can't figure out how to control the array precision similar to the attached example's control of a simple float control.  Can it be done?
(2,868 Views)
Hi RAMaston,
you can create a property node of the numeric element in the Array not from the entire array. Select the single numeric element in the array and create the property of it in the same way like the property of the other numeric indicator.
Mike
Message Edited by MikeS81 on 03-19-2008 02:34 PM
(2,867 Views)
Thakns much,  Forums are great. Tell your boss I said take the rest of the day off!
(2,859 Views)
