programatically Setting SCXI-Gain
I would like to programatically make settings on the SCXI 1520 Strain Gauge module. When i want to set SCXI Gain with AI parameter.vi iam wiring the gain value i require to float in parameter,but i get an error such as "numeric Parameter is invalid",what could be the reason?
(2,777 Views)
Hey Murali,
Here is a discussion forum thread that has already addressed this issue from the traditional NI-DAQ side.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=50650000000800000048880000&ECategory=Measurement+Hardware.Multifunction+DAQ
With NI-DAQmx you can get and set the gain for specific SCXI channels using the DAQmx Channel Property Node->Analog Input:General Properties:Advanced:Gain:Gain Value Property.
I hope this helps out,
Joshua P.
Application Engineering
(2,777 Views)
