programatically add pictures to ring
Hi
How to programatically add pictures to a picture ring?
Message 1 of 9
(6,723 Views)
Hi swathi,
afaik, this is not supported and i'm not sure if scripting can handle it.
You can use an array of picture controls instead of it.
Mike
Message 2 of 9
(6,710 Views)
ok.Thanks for your reply..
Message 3 of 9
(6,701 Views)
The scripting interface does not have this functionality, either, and requires the full development environment (hard to deploy).
What are you trying to do?
The array of picture controls mentioned above is a good option, as is a simple picture control you load images into.  You can get custom pop-up menus to imitate the selection list of a pict ring.  You can probably produce the interface you want, but it may take a bit of work.
Message 4 of 9
(6,681 Views)
You can programmatically add pictures to a Listbox. If your pictures are tiny, maybe this would work for you.
Richard
Message 5 of 9
(6,667 Views)
I know this post is old, so maybe someone has already figured out how to do this.
I did this by creating an executable using AutoHotKey.  Attatched is the *.vi and *.exe you'll need.  The original AutoHotkey script is also attached, but not needed.
For anyone who is interested, AutoHotkey is a great tool for automating redundant procedures.  It's also great for creating short cut keys for tasks you do all the time.
http://www.autohotkey.com/
Message 6 of 9
(5,904 Views)
hi, can you save and upload the vi on LV2013 ? thanks
Message 7 of 9
(5,814 Views)
See attached.
Hope this helps you!
Message 8 of 9
(5,770 Views)
yes, this will do the job. not what i was expecting (scripting ) but it works.
thanks.
Message 9 of 9
(5,704 Views)
