programatically associating a .rtm file to a control
Is there a way to programmatically associate a .rtm file to a control as we can associate a .rtm file to the VI Programatically.
I know the method where we can give the String array constant to Insert Menu Items VI.
I was just curious if we can have different-different .rtm files associated with the control. I know that it is possible with different(simple) file types but i wanted to know if there is any method available to do it with .rtm files.
Also is there a way for reading .rtm file formats??
Krunal
(3,123 Views)
(3,112 Views)
Thanks for the reply Muks,
Actually i am looking for something similar but these .rtm files should be associated to controls run time menu and not VI's..
I know there are methods to do so, but i am specifically looking at .rtm file implementation to get knowledge about the same..
I hope i m bit clear this time.
Thanks again,
Krunal
(3,109 Views)
