02-05-2007 01:16 PM - edited 02-05-2007 01:16 PM
Message Edited by Chris Co on 02-05-2007 01:18 PM
02-06-2007 05:39 PM
02-06-2007 09:16 PM
Just so I'm clear.
I can write a program that has the ability to compare the dynamically created task with the modules for the specific channels. And after they do not match properly, shut the program down, open max, configure carrier, re-enter info again to dynamically create the task, check again to see if done properly, then continue?
I understand there may be a driver configuration issue, but still it would seem to be acheivable. I do not want to shut the program down, besides not all people know about the different device characteristics like "hot swappable" and "you didn't just hot swap that module did you?".
This is just some of the things I would step a user through. AND without making them angry because they have to enter the information again. (I'm fairly positive MAX absolutely hates it when you try to configure anything with its resources hanging in the breeze.)
Chris Co
02-08-2007 06:10 PM
02-08-2007 09:07 PM
02-09-2007 08:59 AM
