programatically displaying data points
I have an xy graph which I would like to programatically display the some of the data using only symbols. I'm using a property node, but can't find the correct property to accomplish this task. Any suggestions?
(3,372 Views)
For a single plot, all points have to have the same point style, color, and line style. To display some of the xy pairs differently, you'll have to extract those points and create a new plot with just those points and use property nodes to assign point style, etc. to the new plot.
(3,372 Views)
I have done this. I have defined point styles, etc., but I can't figure out how to make the line connecting the points disappear. I'm looking for the property to specify no line.
(3,372 Views)
Its Plots.Interpolation. A value of 2 is the default and a value of 0 will set to no interpolation - no lines between points.
(3,372 Views)
Thanks, I would of never found it there.
(3,372 Views)
