programatically edit combobox
Need to programmatically edit (add and remove) items from combobox dropdownbox in run-time application.
This must be common task, however both online examples found do not work.
Suggestions?
(4,637 Views)
you can use the visible property node
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,633 Views)
Umm... that would just hide/show the control. ???
To edit the list of items, just use the String[] property. What examples are you referring to?
(4,630 Views)
wow I missed the question sorry about that, I don't know why I thought of checkbox when you said combo box
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(4,625 Views)
Examples that do not work:
This one does not work run-time.
http://digital.ni.com/public.nsf/allkb/1E180530E05E4DB28625731C006CCB5A?OpenDocument).
This one simple does not maintain items while editing them.
http://decibel.ni.com/content/docs/DOC-6265).
(4,614 Views)
The first link you provided doesn't point to an example. It points to a generic KB article about some properties and/or methods not being available in the Run Time Engine.
The second link you pointed to is an XControl, not a combobox. Totally different beast. Your original question was how to programmatically add/remove items from a combobox. As noted, this is done by updating the Strings[] property. If you are having problems with that XControl then you need to post in that community page so the author of the control can help.
(4,600 Views)
A five minute example.  It doesn't operate quite like I would expect from a real app, but it illustrates the Strings[] property
Tim Elsey
Certified LabVIEW Architect
(4,591 Views)
