programatically edit graph scale
I kow that I can edit graph scale values simply mouse clicking on them, and typing new values.
Now I want to reproduce this behaviour programatically, but the problem is that I can't use the mouse in my application (only keyboard is available  Smiley SadSmiley Sad )
So, is there a way to programatically get focus to scale boundaries (x_min, x_max, y_min, y_max)?
I hope so...
 I need to programatically setting them.
Using LV 6.1 on Linux Fedora Core 3
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,193 Views)
Hi vix
You could create a vi which represents a Num-Pad to enter numbers via mouse. Maybe there already exists something like that - just search the forums or google the net.
This values you can pass to a property-node to change the scale.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,192 Views)
Thanks for the suggedtion,
but I want to avoid "complicated solutions".
I need an interface very, very simple.
I thought using 4 numeric controls over the boundaries, and edit them.... if no different ideas
Vix
Using LV from 7
(3,186 Views)
I'd have suggested this too - but you may be limited. Imagine you have set your control to increment by 0.01 (for precision reasons) - how long may it take if you want to set a value of 50?
By the way - building a num pad is not that complicated. Of course it takes time to accomplish, but I think you are most flexible.
Using LV8.0
(3,180 Views)
