programatically get the states of case structure
Dear all,
Is there a way we can programatically get all the states of a case structure in my VI.
I know that there is no property node for case structure, but I am sure there must be some way that labview ppl must have thought about it.
Awaiting....
cheers
Sree
Message 1 of 11
(4,482 Views)
Accepted by topic author Sreedhar_T
Hi Sree,
it should be possible with scripting. As a start you can analyze the "Tunnel Wiring Wizard".
Mike
Message 2 of 11
(4,475 Views)
With scripting, there is a property node for the case structure and you can query the names of the cases.  You will need LabVIEW 8.6 or greater for scripting.  Get started here.  Note that scripting is unsupported, except through the scripting message board.
Message 3 of 11
(4,466 Views)
Any other way than procuring scripting license 😞
Message 4 of 11
(4,435 Views)
Hi Sreedhar,
where is the problem, it's for free.
Mike
Message 5 of 11
(4,427 Views)
I am not sure if its for free... I tried installing it. Now it is asking for activation code from NI License manager.
Could you pl confirm
Regards
Sreedhar
Message 6 of 11
(4,414 Views)
Hi Sreedhar,
it's for free! It's for registration and to check if you have a valid LabVIEW license, i think it would not work with an evaluation version.
Read this for further information.
Mike
Message 7 of 11
(4,408 Views)
You can find an example of getting the names of the elements in a case structure here.
Message 8 of 11
(4,394 Views)
Kudos,kudos,kudos... the code works perfectly for me 🙂 Thanks a lot.
Mike, I think you are right, it will work on licensed labview machine. I tried on an evaluation one.
but do I need to register on internet after I install it ? does it mean that if I am using a machine which is not connected on internet, will it not work?
Regards
Sreedhar
Message 9 of 11
(4,353 Views)
I think you need a machine with internet only for the registration/activation purpose, not for working normally after this...
- Partha ( CLD until Oct 2027 🙂 )
Message 10 of 11
(4,343 Views)
