programatically label xy graph
is it possible to programatically label an xy graph, updating the label using a property node everytime the graph updates?
(3,491 Views)
prbably better to use the caption instead of the lable for labling a graph (since the lable is user for many other things keeping it constant is a good idea), but this is a property node caption->text
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,487 Views)
  I have the same issue about programmatically changes the label with a property node, it does not work, I get error 1073. So I am changing the caption, which works. Any ideas what is going on?
Regards
Kaspar
Kaspar
(3,342 Views)
You cannot change a label at run-time. The description for the error code says:
 This property is writable only when the VI is in edit mode, or this method is available only when the VI is in edit mode.
Think about it: If you change a label at run-time, how would something like an event structure work?
(3,332 Views)
