programatically starting an application
Hi all
I am creating an application(APP1) which will run on RT PXI. I need to start this application only if I receive a specific command over TCP/IP or DATASOCKET. Reading data over TCP/IP or DATASOCKET is done by another application(APP2) which runs on the same RT PXI. Or basically what I need is to start APP1 from APP2, can anyone tell me how do I achieve this?
Thanx a lot
Arun
(3,140 Views)
I haven't tried this with the real-time engine, but on a PC you would get a reference to the VI (let's say by using open VI reference) and wiring that reference into an invoke node with the Run VI method selected. Set Wait until done to F to allow your VI to continue running. Both functions can be found in the Application Control palette. If this doesn't work, you can simply place your VI inside a case structure inside a loop which waits until a flag is recieved to run the VI. Set the flag when you recieve the command.
___________________
Try to take over the world!
(3,128 Views)
Continuing along the lines of Tst's answer, here is a link to an example program that demonstrates running one VI from another VI using VI server.
I hope it helps.
Ankita
(3,105 Views)
Thanks a lot for the example, thats exactly wat i needed, but saw it very late,
thanks again
(3,070 Views)
