programmatic create library using DSC module LV 8.2
I assume a need a library for any SV programmatically created... yet I don't see a way to create a library programmatically in LV 8.2 DSC. Another post show a VI for this using version 8.5.  Someone tell me if I need to create a library programmatically if I'm creating SV programmatically? If so, then how???
richjoh
(6,663 Views)
OK in DSC 8.2, there is nothing to programmatically create SV Library (Modbus). I only see VI to save a Process or SV to an existing library.... Am I correct here???
(6,658 Views)
Hi richjoh,
Are you referring to the Save to Library VI?  If the library path lists a library that does not exist, it will be created.
Jennifer R.
(6,164 Views)
