programmatic i/o variables with 9205
I'm using the I/O variable nodes provided by NI. I'm using them to dynamically read/write to a cRIO. My problem is that the values on my 9205 c series nodule isn't very accurate. It will jump from the level I expect to some lower value periodically. I traced this back to the i/o variable reads. I'm using scanned reads. is this indicative of a bad card or is there something else going on?
JY
(2,368 Views)
Accepted by topic author jeffyy
Topic Solved
(2,350 Views)
